why cant i use a LT1 intake instead of MINIRAM ?
ok just wondering here, so i thought i ask, why cant it use a lt1 intake , instead of buying a mini ram, what would be diffrent between the two, would the fabracation be worth it, allso, will lt1 injectors work with a l98 tpi motor, , any advice on this will help alot, thanks
89 l98 350 soon to be 383 with hotcam ,
Car: 89 IROC-Z
Engine: 383
I'm pretty sure a Lt1 intake is setup for reverse cooling. Someone else would know for sure though.
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
--RPM Racing--
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
LT1's are distributorless, they use Optispark upfront off of the timing chain cover to generate spark pulses.
Therefore, there's no distributor hole in the back of the manifold.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
KevinP92Z
AHHHHHHHH thats right i think they are, damn gm lol, hummmmm is there anyway around this,what about cutting the box off, and welding it to a edlebrock intake ? i know but 1200.00 is alot of money for miniram,considing i still need heads, allso anyone have the part numbers for svo ford injectors, and what the price might be for them ?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The water passages dont line up, and I think the intake port passages dont line up either. But you could always modify it to fit for $$$$.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I believe you're going to run into more trouble than it's worth trying to put that LT1 intake on there!
The LT1 injectors, however, will work with an L98! I picked up my used 24# LT1 injectors from www.speedautomotive.com for $25 plus shipping and now I'm having them cleaned and flowmatch by Cruizin' Performance for $80! I think paying just over $100 for a set of 24# injectors that flow BETTER than they did from GM is better than paying just over $200 for some SVO injectors!! Just my opinion!
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
It sucks that the LT1 intake won't fit our L98 motors. I could have picked up two at the spring Daytona car show for $75 each! I guess LT1 heads won't drop on our block cause of the water passages?
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
</font>
This has been done . You would have to machine in provisions for the distributor and tap into the coolant passages in the head and loop the coolant flow . Coolant doesn't flow thru a LT1 intake . I've also seen circle track racers use iron LT1 IMP heads , again though , you have to make it work .
Do a search on cz28.com in the for sale section for a 90 RS . This guy was selling his car and did make a LT1 intake and ported LT1 heads work with a Gen 1 block .
Derek 90 IROC 5.7[/i]
Mods: All the usual bolt ons , 2500 stall , 373's , SS hood , lotta reduced weight.
Best Et: 13.16@101
[This message has been edited by 90 Z28SS (edited April 26, 2001).]
Best Et: 13.16@101
I dont think its worth it. For the price and hassle of LT1 heads and intake on your regular small block, you can either get the whole LT1 engine, or get AFR heads and a MiniRam on your small block.
The LT1s ports will line up but all the bolts won't. I'm guessing GM did this so people don't bolt on an intake that has no water passages running through it. They probably changed the bolt pattern on the Vortecs because the intake ports were different too. If you want a mini ram, this thing is only $255
http://www.holley.com/HiOctn/ProdLin...901-101-1.html
If you still wanted to modify a LT1 intake, I bet you could have the right intake hole drilled in, the rear distributor hole put in too. For the front. you might be able to cut off the part below the TB and weld front of a carb intake on .. GM did something like this on a 406cid Monte Carlo concept, the green one. I have an article on my website on how to make LT1 heads fit GenI blocks(not that its worth it anymore now that Vortecs are here).
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Soon to be installed:
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited April 27, 2001).]
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
New2Chevy
Sep 28, 2015 12:35 AM
toronto formula
Sep 10, 2015 07:31 AM
