code 32?
Old Apr 29, 2001 | 07:43 AM
custman87T/A's Avatar
code 32?
I get a code 32 EGR Failure at start up when engine is cold. After about 2 mins. of driving the SES light goes away. When it is warm and I restart the light doesn't light. It only happens when cold. I would appreciate any ideas...thanks.
Old Apr 29, 2001 | 06:30 PM
CanadianBeast's Avatar
There is a tech article about this in the tech section, then after that there has been about a million posts about code 32. Good luck, by the way in my case it was a faulty coolant temperature sensure (code 15) that seemed to be triggering the 32.
Old Apr 29, 2001 | 11:32 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I had the same problem. Code 15 and 32. I had no heat in the fall and colant wasn't going to the heater core. After some investigating I found out that the radator was replaced at some time and the nincompoop that did the job didn't remove a plug from the radiator.After that no problems(No Codes) until recently. I suspect the EGR. didn;t investigate yet.
1990 Formula
Factory:TPI-305/Dual Cat(230hp),5 Speed,3.42 rear, Dealer:Aluminum Drive Shaft
Mods:SLP air foil,K&N Filter, Accel:wires,coil cap,rotor.Hypertech Thermomaster chip,Stat,Fan switch,TES headers,MSD6AL,AFPR(46), Harwood fiberglass hood,original GM "Notchback GTA" hatch.
Flowmaster 3" Cat-back exhaust,TB coolant bypass, Centerforce dual friction clutch.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
