Injector woes
Old Apr 30, 2001 | 03:20 PM
Maverick13's Avatar
Injector woes
Seems my 305 injectors are starving the new 350 to death. Bleh. Anyone know of a place to pick up good 22lb injectors (doesn't have to be Accel or Holley, etc -- just OEM or better) without breaking the bank? I checked the usual places AutoZone, GM, Jegs, Summit, but everyone wants anywhere from $500-800 for a set of 8. Maybe I should try a boneyard?
Maverick
1989 Formula 350 TPI
5spd Tremec 3550/TKO
several suspension mods
Old Apr 30, 2001 | 03:28 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
it'll be hard to get just the injectors they usually want to sell the complete unit howver on a stock motor 19lb. injectors are fine you just need the injector pulse width changed in the prom to flow the amount of fuel for the 350(that means a custom chip)
Old Apr 30, 2001 | 05:35 PM
Fredzep's Avatar
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
I have the same problem with my 305 top on my 350 bottom. I feel that I am not getting enough fuel to the new motor. I ordered Ford Racing 24# injectors today from Summit $219 and will put them in Tomorrow or Wed when they get here. I will let you know if they fit and if the help. I also am using a fuel pressure regulator running 46 - 52lbs.
Fredzep
90 GTA 350 5Spd
TPIS, SLP, Borla, K&N Mods
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
