Changing fuel injectors, do you have to remove plenum?
Do you have to remove the plenum and runners to get to the fuel injectors. I'm looking for any tips or shortcuts for the install.
Thanks, Dave
Thanks, Dave
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
i've done em twice it's easier to remove the plenum and loosen the runners till they slope outward then it's a ten mm socket to remove the four bolts holding the rails down along wiith the bolt just behind the water pump i just left that bolt off during reassembly no need for it
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A half hour to change fuel injectors? Damn, you must be The Flash!
Yes you have to remove the plenum, but you only have to loosen the runners. I changed mine in about 3 hours.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I have to loosen the runners on my car. The fuel rail will not fit between the egr and the runner. SInce it's a ZZ4, I'll probably get an egr block off plate and avoid the hassle in the future.
Remember to but a little vasoline around the o-rings so if you ever have to pull them again, the o-rings don't stick and tear.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Some follow up q's: when you remove the plenum, do you also remove the TB from the plenum. And, where do you get and what type of gaskets do you get get to replace the old ones.
Thanks, Dave
Thanks, Dave
<font face="Verdana, Arial" size="2">Originally posted by dnovotny:
Thanks, Dave </font>
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
keep the tb on , its much easier, you should be able to reuse the gaskets, if not go to a local parts store and pick some up.</font>
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Car: 1986 Firebird
Engine: 2.8 V6
When I worked on my injectors, I re-cut those plenum gaskets out of a sheet of thin, black gasket material. I used the originals as templates, an X-acto knife for the cutting, and a punch for the holes.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
I would kill to be able to change the FI's in 4.5hours!, it only takes me about 1.5days...
(seriously)
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
(seriously)
Brendan
Firechicken86
Aug 12, 2015 10:07 PM
