Another Wont Start problem
Old Nov 15, 2007 | 07:41 PM
OneLeetIrocZ's Avatar
Car: 1988 Iroc-Z
Engine: 388 Stroker
Transmission: T-56 6speed
Axle/Gears: 3.45 9-bolt
let me start by saying that everything was fine with the cranking of the car prior to this. i replaced the injectors with Ford motorsport injectors, because i was having an idle problem. after getting it all back together, i prime the fuel pump 3 times to get pressure, then i crank and for about 3 seconds and everything electrical turns off... fan, gauges, dome light, door buzzer... everything. kind of like i unhooked the battery, i checked the connections at the battery and they are tight and clean. the positive wire was kind of hot though. so after being confused for a bit, i go to call it a night, and everything is back on, so i try to crank again, and only for a split second does it crank and everything electrical dies again, wait for a bit, comes back on, try again, everything dies again, soon as i crank, not when in run. dont know what could have caused this, only thing electrical that i had to unhook was the maf, tps, iac, iat, and injector clips. and all those are back intact.
by the way this is on an '88 iroc-z L98 car that is 100% stock except for k&n's, flowmaster, and now injectors.
Old Nov 15, 2007 | 07:51 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Re: Another Wont Start problem
First thing you did wrong was put Ford parts in a Chevy.
Kinda sounds like a bad ground. Possibly VATS related. May be wrong though, just a suggestion.
Old Nov 16, 2007 | 12:23 AM
Car: 1988 Iroc-Z
Engine: 388 Stroker
yea i thought i might be a bad ground too, but i didnt have this problem before, unless now that i think of it... there is a rod that connects from mount on the back of the alternator to the intake next to the thermostat, but i think that its only for support of the alternator, but i could be wrong, could that be a part that continues ground somewhere? i didnt put it back on yet because i cant find the nut that goes on one end.
and as for VATS... its an '88 car, so no vats.
trouble codes = none.
Old Nov 17, 2007 | 02:34 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Cable getting hot maybe from extended cranking of the engine, short, or loose cable at starter,or loose battery to engine ground.
There are three grounds near the firwall - copper stranded strap to firewall, and wiring loom grounds behind each head, at least that what's on my motor.
Old Nov 18, 2007 | 10:13 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
might want to check the fusible links at the starter as well. i had one go bad and it caused similar issues.
a lot of us are running ford injectors in our set-ups. works quite well.
Old Nov 18, 2007 | 02:07 PM
Car: 1988 Iroc-Z
Engine: 388 Stroker
i fixed the problem.. turned out it was the cable that was "clamped" in the terminal was corroded/loose. cleaned it up and tightened it down, and it fires fine now. it was one of those cheapo autozone terminals, that i have gone through numerous times in the past.
oh and btw... replacing the injectors did not help for my rough running problem... im looking further into it.... im only getting 8-10 Hg of vacuum at idle and it rapidly bounces up and down between those values, but smooths out with higher rpm.... im going to have to start a new thread once i figure out what i need to ask, if i cannot find out through searching. Thanks for helping.
Old Nov 18, 2007 | 02:25 PM
Jason1313's Avatar
Car: 92 Camaro RS
Engine: 5.0 TBI
Glad you got it figured out!
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
