Bad fan relay or what?
Old May 8, 2001 | 10:30 PM
ScreaminDeamin85Z's Avatar
ok my dead bone stock iroc begins to overheat while im sitting in traffic for lets say 5-10 minutes, but once i start driving down the road again it cools back down.i havent really looked into this problem that much but i can tell you that when i get to my driveway and open the hood(car is in the 240* range) that neither of the fans are running.i dont know if it is my stat sticking or what. on my black car i had it rigged so that the fan was on all the time when the engine was running.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC-Jamex Springs...and thats just about it till summer!
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old May 8, 2001 | 10:41 PM
AfootVoyager's Avatar
hey there SD...check your fan switch located in the passenger side cylinder head...might have died...you not too far from me and it gonna get hot again this year so we had better be ready...i already have my single fan hooked direct to switch...looking for dual setup now...
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Old May 8, 2001 | 10:47 PM
hehe yeah its gonna be hot this summer...when isnt it hot in this state? besides Jan. i will check the fan switch in the morning. where is Newton anyways?
Brandon
Old May 8, 2001 | 10:52 PM
55 miles north of Orange which is about 20 east of Beaumont...lol...BTW I bought my car in Katy in january and blew up the radiator on the way home...right there on the freeway bout 3 miles from beltway 8....food for thought..
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
Old May 10, 2001 | 05:06 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I just spent all day Sunday fighting that fan in my 86 IROC! The switch in the block is easy to check/bypass. Start the car, ground out the wire coming off the relay and see if the fan comes on. You should also be able to start the fan by turning on the AC, once the system pressure gets up to about 230 psi in the AC system. On mine I have 4 wires going into/out of the relay (located between the battery and radiator). The orange wire is power from the fusible link to the relay, the tan wire is power from the fuse box to operate the relay, the black/red wire is power from the relay to the fan and the green/black wire runs (basically a ground) to the temperature switch in the block. You can pull the connector off the relay and jump across the orange or tan wire to the black/red wire to see if the fan runs. I had power every where I should have had (when checked with a meter) but the fan would not run when I jumped across the orange (power wire) to the black/red wire. Turns out the wire from the fusible link (coming off the pos. bat. cable) was basically in two right at the connector. I had a good enough connection to read 12 volts (on the meter) but not a good enough connection to push enough current to run the fan motor (drove me nuts till I figure it out by trying to jump across those wires). If it is the relay Advance Auto sells them for $9.95, I just bought one for nothing.
Z's r Best
TheTraut88
Sep 11, 2015 05:16 AM
greenyone
Sep 2, 2015 03:39 PM
RyanJB
Sep 2, 2015 01:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
