symptoms of oversized injectors
Old Nov 20, 2007 | 07:37 PM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
friends formula 350 had new fuel injectors installed its a 91 when the car starts up the exhaust fumes make your eyes tear but goes away after it warms up is that cold start mode just dumping in a lil bit more or is that running rich till warm up a diffrent reason? theres no black smoke , back firing or SES the car is mostly stock cold air intake and smog pump delete and a flowmaster thats about it any ideas?
Old Nov 21, 2007 | 09:57 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: symptoms of oversized injectors
Sounds like a leaking injector even though you say they are new. Hook up a fuel pressure gauge, and see if it bleeds off with the KOEO.
Old Nov 26, 2007 | 09:38 AM
tmviper's Avatar
my car does the same thing. i have a 350 w/ 24 lb injectors. when you start the car up, it is in open loop(not using O2 sensor), so it could be running rich until the O2 heats up. he should get an adjustable regulator, and that will prob help, but it shoulnt be much of an issue. too check for a leaking injector, pull the fuel rail out of the intake, leave all the lines and injectors connected, and turn igt on engine off. look at the nozzles to see if they are leaking.i dont think thats it, but its better to spend the time to check, rather than hydrolock the motor.
Old Nov 26, 2007 | 09:40 AM
Car: 1985 TransAm
Engine: 5.0L TPI
i check the injectors there is no leak , i found out the prev owner had dumped alot of stabil in the tank and it deff smells like burning stabil also , the ign system could use a lil upgrade and the timing could be bumped up a degree
BumpaD82
Feb 26, 2016 02:57 PM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
