Need help with fuel system...
Old May 10, 2001 | 06:56 AM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
What should the fuel pressure be after you first put the key in and the pump runs for about 2 seconds?
When I try to start, my pressure only comes up to 15 to 20 psi. WTF? If the car starts, the pressure is around 45 psi. I've tried blocking the return line, the pressure went up a little.
Need some advise quick.
TIA
Bob
Bob '89 Ram Air Formula 350
Last(lost)Member of the Elusive Great Lakes Crew
My car's homepage
Old May 10, 2001 | 08:15 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
If my memory serves me correctly, it should be like 40-45, and actually drop once you start it, by a few lbs.
KAM
Old May 10, 2001 | 07:03 PM
RCR's Avatar
RCR
If the pressure starts low, then goes high after the car starts, what's wrong? I checked the relay and it seems fine.
Help?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
