86 throttlebody on a 90-92 plenum butttt!!!
Old Nov 21, 2007 | 08:03 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
ok the plenum I have is a 90-92 piece but where its throttlebody mounts that area has been opened from 2 holes to like 1 huge hole .... so will the 86 throttle body work fine cause I notice a air passage in the middle of the 86 throttlebody.
Old Nov 22, 2007 | 11:14 PM
Jproz1167's Avatar
Re: 86 throttlebody on a 90-92 plenum butttt!!!
does anyone know the answer to this before I go through with polishing this 86 throttlebody???????
here is my plenum.
Old Nov 23, 2007 | 12:56 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Yes, in that case, the '86 throttle body should work. The reason why the early throttle bodies typically require a matching early plenum is because the IAC supply, located between the two throttle bores (and slightly below), has to have a matching hole in the plenum. Since that whole area is removed on the late plenum that you have (the plenum must be setup for one of those mono-blade throttle bodies), you'll still have IAC supply. Go for it!
Old Nov 23, 2007 | 02:05 PM
Jproz1167's Avatar
Old Nov 23, 2007 | 07:14 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Agreed.
Old Nov 24, 2007 | 11:36 AM
Jproz1167's Avatar
Think I'm just going to skip polishing and putting the 86 stock throttle body on this system anyways since it's not really suited for this TPI since everything else is setup for a larger throttle body anyways.
toronto formula
19
Oct 6, 2015 12:27 PM
hartsmike
Oct 4, 2015 01:00 PM
Randomtask2
Sep 10, 2015 08:37 AM
