What in the hell just happened?
Old May 11, 2001 | 10:17 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Hey there guys, i havent been here in awhile due to some wife problems but I have since gotten the worked out. Boy I almost lost it all.
Anyway I was driving my car today and all of a sudden it started to sputter and the SES light came on and flickered and then just stayed on from there.
When I got hoem to see what code it was giving, it wont tell me the light just stays on with or without the clip in. What in the hell is wrong now?
I looked under the hood and cant see anything loose or anything. What would cause my car to all of a sudden start running like **** and make the SES light stay on like that...?
Thanks guys
microtech8@triad.rr.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
My Car: http://albums.photopoint.com/j/ViewP...240&p=36621420
Old May 12, 2001 | 12:46 PM
james_fearn's Avatar
EGR?
James
Old May 12, 2001 | 08:31 PM
El Guapo's Avatar
maybe your computer bit the dust. There are only a couple of possibilities about the SES light.
1) The computer is doing it
2) The ground wire, all of a sudden, broke and somehow grounded itself.
If the computer died, it would go into limp-home mode, which could cause the problem you mentioned. My sugg would be to try a new prom.
Clayton
Old May 12, 2001 | 10:24 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
If you can't ground the ECM to pull codes but could before, look at the ECM, then the PROM. Computers don't last forever. Be sure to check for voltage at the ALDL to make sure it's not a wiring problem.
RS Reaper
Oct 17, 2018 07:52 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
