Wire that I do not where it goes
Old Nov 23, 2007 | 10:03 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Hello, I have a wire that goes with same wiring loom of the knock sensor. The color is black. Does anybody knows what is for? Thanks, Ivan
P.S. harness is out of 88 or 89 TPI Camaro
Old Nov 24, 2007 | 09:29 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: Wire that I do not where it goes
is your fan temp switch hooked up? it is the passenger side head between #6 and #8 spark plug.
Old Nov 25, 2007 | 02:47 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The passenger side fan switch will have a green wire with a white stripe. Are you sure the wire is black (make sure it is clean)?
Old Nov 28, 2007 | 10:44 AM
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I just checked it out and it is black
Old Nov 28, 2007 | 11:46 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
How big of DIA is it? Is there a hoop on the end, plug, cut off, etc?
Lower pass side of motor...
Fans (green/wht)
Knock sensor (usually blue)
Starter... Usually orange, red, ppl.
Smog pump??? But thats 2 wires.
But almost always, black is ground. Is there a ground hoop anywhere close that is still bolted down and the wire ripped loose?
:edit: another thought. Is there any holes, or toggle switches in the dash that you dont know what they go to? Someone could have wired up a toggle switch to turn the fans on, and its now laying there. They would have tapped into the green/wht wire somewhere.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
