A/C and smog pump eliminators
Old May 9, 2001 | 11:40 PM
dot's Avatar
dot
Does anyone make a Smog Pump and A/C eliminator kit???
1989 S10 Blazer 355/700R4
Old May 10, 2001 | 12:27 AM
lb9formula91's Avatar
i know that GM sells a AC delete pulley. IT goes where the AC pulley used to be if that helps any
91 formula
305 tpi
342 Rear
borla cat back
white face gauges
home made cold air
tpis airfoil
crane afpr
msd 8.5 mm wires
msd cap and rotor
AC Delco Rapid Fire plugs
soon to have ported plenum and intake
We light the tires, so we can fight the fires!
Fighting the "RED DEVIL" on the southside of bethpage!
Old May 10, 2001 | 09:43 AM
Kyle F's Avatar
Smog pump no, but there is and Idler puller that will replace your A/C system that is available through GM. My brother has one on his TBI.
Find him on the TBI board and ask him about it he can tell you where, or how he got his.
His user name is Brian F or Brian Felts. I forget which one he is using now.
Old May 13, 2001 | 10:03 AM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
GM sells an idler pulley that replaces the smog pump (OE on middle-eastern vehicles). The part # is 10186767. It should run around 40 bucks from the dealer.
Old May 13, 2001 | 10:21 AM
drain89's Avatar
Yes, GM does make a smog pump eliminator. They originally came on middle-eastern bound cars where there's no emissions. It's part number is 10186767. It should run about 40 bucks at the dealer.
"Honey I do this for a living, I don't need to turn off the breaker...(BZZZZZ) Oh ****! Damn that hurt!"
italiano67
Dec 11, 2016 09:21 AM
diana227vegas
Jul 8, 2016 12:27 AM
Glowsock
Aug 31, 2015 09:01 PM
lakeffect2
Aug 23, 2015 08:44 AM
