TPI virgin needs info
Old Nov 26, 2007 | 02:27 PM
northeaster79's Avatar
Car: 89 WS6 FORMULA
Engine: LB9 305
Axle/Gears: 2:73 posi
I have recently gotten my first third gen.F-body.love the car,needs more power,its an LB9 and its stock except for the K&N drop in filter and a RHYNO cat back,I'm going to put a set of headers and larger Y-pipe and either a gutted or high flow cat.where should I go from there?all of my previouse toys being carburated and I don't want to carb this one,the TPI system is way to good to look at.any information you veterans have to share will be apreciated.
Old Nov 26, 2007 | 03:03 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: TPI virgin needs info
well since you want to pop your cherry depends how you want it. you can do a cam that will run well of the stock tune, better gears/posi(if you dont have one), maybe port your heads or buy a new set, etc etc list goes on depends on how much more you want out of it and how much youre looking to spend.
Old Nov 26, 2007 | 03:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Basically, everything you can do to a carb motor, you can do to this motor. Just some of the parts will have different names.
Changing jets=changing fuel injectors(and the prom chip)
Adjust timing= adjust base timing
changing your vac advance timing=redoing the prom chip
going from a 600cfm carb to 750cfm=larger throttle body
tell us what you want to do, and we will tell you the EFI name.
Old Nov 26, 2007 | 09:54 PM
Car: 89 WS6 FORMULA
Engine: LB9 305
well some of the reading I have been doing I will definatly be going with the hooker 2055 headers and y-pipe,then a high flow or gutted cat.then I was thinking an L98 cam,22lb injectors and a holley 52mm tb,and while I was at it port the stock intake system,should be able to pick up a few hp with that.maybe a set of march pullies and a programer of some type.found a low millage 4th gen rear with 3:42's,unsure of using one because I want to use the stock wheels.I like to keep my cars as stock looking as possible.
stalkier
Dec 6, 2015 11:25 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
