What else do I need for a swap
Old Nov 26, 2007 | 08:56 PM
praterjason's Avatar
I bought an entire 305 TPI engine from someone, with the computer, harness and everything. My car currently has a 305 TBI in it. I was wondering what else is required to be changed to make the car run. It is out of an 88 fbody just like mine. And where can I find an air intake for the car as well, Don't want to go with the OEM setup.
Old Nov 27, 2007 | 01:25 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: What else do I need for a swap
Read the tech article on swapping a TBI to a TPI, that will give you an idea of where to start.
You dont have to use the wire harness, you can repin the one you have, if you are up to it.
You'll definitely need to drop the fuel tank and install a high pressure fuel pump.
Do a search of these forums and you'll find lots of posts over the years to help you out if you get stuck. If this is your first major project, I highly recommend finding a friend with experience to help you. This isnt something you can do in an hour or two. It'll take a day or two, or three.
Old Dec 3, 2007 | 08:11 PM
I know my way around cars pretty good, but this is just the first time dealing with a TPI system. The person I bought the setup from is the one doing all the work, but I will probably have to do the fuel pump portion. Thanks for your help with this.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
