trans oil pump leaking
Old May 15, 2001 | 11:54 AM
sonnyb's Avatar
My 700r4 trans oil is leaking from the front pump seal. I replaced the front pump oil seal and the leaking is still there. I think there may-be something inside the pump that may be causing the pump seal to leak. Do anyone site have insights on this problem.
Old May 18, 2001 | 01:00 AM
Guest
Guest
Posts: n/a
2 things:
The converter where the seal rides, was it worn? And I have seen out of balance converters take out new seals, although I dont think thats what it is.
Another problem area is the bushing. If the seal was worn, the bushing probably was too and thats what took out your new seal. Thats the most likely suspect.
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Exxon Limited
Aug 9, 2015 08:13 PM
