Studder and hesitation
Old May 17, 2001 | 11:41 AM
eatmydust's Avatar
Car: 1986 IROC-Z28
This just started yesterday after I filled up at a gas station. When i'm at a dead stop or driving kinda slow and I hit the gas it kinda hesitates a little. Anybody know what that could be. I noticed my oil pressure was just a little below 30 on the gauge. Maybe just some bad gas? Sometimes when its in park and idling and I hit the gas I swear I hear a little bit of a misfire. Could that be related or a different problem?
86' IROC-Z
5.0L TPI
Spohn panhard bar and LCA's
Old May 17, 2001 | 04:58 PM
RoadRocket L98's Avatar
I have the exact same problem. Anyone want to enlighten us here?
'89 Firebird Formula 350
L98, WS6, Red/grey, t-tops, and a 3.27:1 rear
K&N, TB bypass, no MAF screens, CAI, full Accel ignition, no cats, Hooker Supercomp shorties, Hooker 3-inch catback
ET? The POS runs 15s.
Also own '83 Firebird 2.8 2bbl. 155K miles.
ET? Break out the calendar!
Old May 17, 2001 | 08:43 PM
86Trans Am's Avatar
When mine started stuttering at low rpm (right after a shift) and at take off, it was the fuel pump going out.
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old May 18, 2001 | 08:31 AM
Steve89GTA's Avatar
I've been trying to solve a similar problem for a year now. I replaced: Fuelpump, fuel filter, Distributor, ignition coil, plugs, TPS, CTS, cleaned IAC, wires(a year old)...no vac leaks. Can't figure it out...
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
New Fuel Pump!
Autometer Vac+Oil Temp
2000 Yamaha R1 150hp 385ibs
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
BLK87Z
Sep 18, 2015 11:29 PM
