383 gm crate motor question
has anyone used the gm 383 crate motor with the tpi setup? would this set up work as a starting point and as funds increase change the cam heads etc and can this crate engine handle the future power of a properly match set up.
when i inquired about it they said that i could be purchased as a short block and i was thinking about using my stock ported heads and induction system....just toying with the idea if it would be feasable to do something like this
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
As far as I know, you can only get the GM HT383 as a long block with vortec heads. So if you find a p/n for a short block 383 from GM, I think I and a lot of others here would like to have it. I have an odd feeling that the dealer you were talking to just wants to get you that HT383 and take the heads off and come up with a price for the short block. They could then sell the heads, or take the heads for themselves. Let me know what ya find out............
Matt
1987 GTA L98 MD8 GW6
"Stop Lights timed for 35Mph are also timed for 70Mph"
Matt
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
it is not a 383 by normal means usually the bore is opened up a little and a 400 crank is installed on the crate motor the bore is still a 4.00 in bore the cylinders will still fill like a 350 leaving out the question of spinning the motor real high the stroke is a special one piece seal 3.80 in it sounds good for a mild motor with a huge tourqe band for towing or racing in a light weight car
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
