Stock 5.7 Fuel Pump - Highest Pressure??
Old May 11, 2001 | 06:40 PM
CamaroX84's Avatar
How high of a PSI rating will a stcok 5.7 TPI fuel pump put out? I have an AFPR. Thanks.
Old May 20, 2001 | 01:17 PM
camarocowboy's Avatar
I have an 87 and my AFPR is set at 50psi and I have no problems and does not run rich w/ the 24 psi injectors if you go higher than 52-53 you can burn the stock pump up reletivley quick.Hope this helps
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
