New Heads and Cam for L98??
Old May 21, 2001 | 05:48 AM
S10Wildside's Avatar
It seems that I'll get the most gain from a new set of heads and cam. The most experience I have with working on engines is from the intake up. I've never swapped heads or a cam. What is the best deal on heads and cam for a L98? What else needs replaced in the process?
1982 S-10 Wildside
355 TPI, Accel High-Flow Intake, Ported Plenum, Arizona Speed & Marine Runners, TPIS AFPR, Edelbrock BBK 52MM Throttle Body, 1993 Typhoon Drivetrain
Old May 21, 2001 | 04:19 PM
Dan87IROC-Z's Avatar
It all depends on how much you want to spend. I would recomend a cam from GMPP, they have better prices than companies like SLP, TPIS, LPE, Comp and Crane. I would go with either the ZZ4 cam or the LT4 HOT cam, both cams are sold for well under $200 from www.gmpartsdirect.com. You can look at lots of different heads. There are less expensive ones from Edelbrock, Trick Flow and World Products, those ones usually sell for less that or just about $1000 for both complete heads. If you have a deeper wallet, you can look at heads from Airflow Research and Brodix. I personally would recomend a set of AFR 190s, they will cost close to $1500 though.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
lt500r55
Sep 1, 2021 01:30 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
midge54
Aug 29, 2015 09:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
