EGR question
Old Dec 3, 2007 | 07:20 AM
rsfromhell's Avatar
Car: 89 RS Camaro, 92 RS Camaro
Engine: 2.8 V6, 305 TBI
Transmission: Built 700R4, 700R4
Axle/Gears: 4.10 richmond, Stock
EGR question
Im getting ready to install a new crate engine and i will be running headers and i was wondering what would happen if i left all the egr crap off and ran the stock prom chip. would it run? would it cause problems or should i get a new chip?
Old Dec 3, 2007 | 08:46 AM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: EGR question
Your check engine light will be on, but it will run. It will be more prone to detonation without EGR as the combustion temps will be higher.
Old Dec 4, 2007 | 02:27 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
Re: EGR question
I`m not running egr or any emissions equipment.I did have it tuned out of the chip though.Havent noticed any detonation problems.
Old Feb 15, 2008 | 03:30 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: EGR question
did you get your egr block off done? If so how does it run?
Old Feb 15, 2008 | 11:33 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Re: EGR question
I bought an egr block off plate from tpis,removed all my smog equipment and had the guy who burned my chip to turn off the egr function.Car runs great.I need to buy some tuning eqipment and dial in my tune but other than that it`s fine.Supposedly it can cost you some mpg`s and as stated be more prone to detenation but I`ve noticed niether problem with my car.If yours is a daily driver and depending on where you live you may want to keep it.Mines not daily driven,50 to 100 miles a week.One reason I may not have had those problems is I`ve read that the lt4 cam I`m running is some kinda of self egr because of the way the valve overlap is or something.I havent researched much about that though just read a couple of posts stating that the lt4 cars had no egr because of the cam.
Old Feb 16, 2008 | 11:52 PM
billyhoss's Avatar
Re: EGR question
yep i too took off all the egr stuff, smog pump and all the AIR stuff and reburnt my prom and all is well
Bubbajones_ya
Aug 28, 2015 02:17 AM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
