EGR passages under the plenum
Old Dec 4, 2007 | 12:51 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
Why does a 86 have two passages yet a 91 doesn't?
Old Dec 4, 2007 | 02:35 AM
AUSSIROC's Avatar
Car: 1999 subaru forester GT (urgh)
Engine: ej20 turbo
Transmission: 5speed
Axle/Gears: 4.11:1 awd
Re: EGR passages under the plenum
Good question. Anyone?
Old Dec 4, 2007 | 12:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Maybe part of the cold start injector??????? My 1989 only has the one port.
Old Dec 4, 2007 | 04:49 PM
AUSSIROC's Avatar
Engine: ej20 turbo
Yeah maybe hey. Do you need to know for a reason or are just curious?
I have a homemade billet egr block off plate that frees up a bit of clutter from that area... easy to make and looks neat.
Also JProz1167, i noticed in your profile that you are unsure of your Vettes rearend ratio. Is this still the case? If so, you know how to check it by rotating the rear tyres?
Old Dec 4, 2007 | 08:00 PM
Jproz1167's Avatar
Can't run without a EGR here ... I was just curious as to why it has two is all ... And would that affect the EGR working if you converted the system to speed density.
Nah not really interested in the corvette it can rot it's life away as far as I'm concerned LOL ....
Old Dec 5, 2007 | 09:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Bingo! One port goes from the driver's side for the cold-start injector. The port from the passenger side is the EGR.
Old Dec 6, 2007 | 01:44 AM
AUSSIROC's Avatar
Engine: ej20 turbo
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
