Stalling prob & bad idle....
Old May 24, 2001 | 09:57 PM
Scott85's Avatar
Car: 91 B4C
Transmission: auto
I just recently traded for an 89 Formula(350TPI) & 90 SHO. I'm having probs with the Formula. When its first started in the morning(or after sitting for awhile) it will stall on the first start, but be ok after that, but then it has a bad idle, and "feels" like it might die but doesn't. It doesn't set any codes. I also took off an Accel 300 ignition box, that the previous owner intalled. Could this possibly be a bad IAC sensor?
89 Formula 350 TPI
Flowmaster, ported plenium, gutted cats, K&N, screens removed, TB bypass.
85 Corvette - Traded
My homepage
Old May 25, 2001 | 02:07 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Based on that limited info, it could be many things, Does it black smoke out the exhaust when you first start it? Could be a/some leaky injector/s. Does it get suficient fuel pressure when you turn the key to the run position? Are the spark plugs in good shape?
You could try cleaning out the IAC passages & setting the base/curb idle correctly if it isn't already.
Also, if you haven't already, it would be a good idea to change the fuel filter, as well as the air filter, check timing & other basic tune up stuff.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited May 25, 2001).]
Old May 25, 2001 | 06:01 PM
trickfbody's Avatar
Sounds like you need to set the IAC and/or it could (the IAC) be carboned up and need to be cleaned. Dont forget to recheck your tps setting after adjusting the IAC.
If you need help with any of this, ask.
Hotrodboba400
Dec 10, 2019 07:07 PM
rjcme
Sep 5, 2015 01:23 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
