egr tube?
egr tube?
I have a set of runners and the drivers side runner has somthing in it like permatex black sealent in the egr tube on the runners on both ends. Should I clean this out will this hurt performance or do you think this was done for a logical reason.
hope you guys can help,thanks
97 formula w/6speed,cags skipshift eleminator, hurst billet pro shifter, 30#injectors,adjustiable fuel presure regulator,Moroso cold air induction,ported mass air sensor,accell300+ ignition box, accell 9000 wires, bosch platnum4 plugs,flomaster crossflow muffler,Lingenfiter 52mm throttle body,TPIS L98 SuperProfile cam,Crane 1:6 full roller rockers,Edelbrock subframe connectors,Edelbrock strut tower brace.
Other car is a 89 GTA w/700r4w/stage 2 shift kit, corvette servo, B&M mega shifter, TPIS bigmouth intake, TPIS large tube runners, TPIS 52mm throttle body,Edelbrock ported centerbolt heads,LT1 24# injectors,GMPP LT4 hotcam,CompCams Pro magnum roller rockers,Edelbrock headers, flowmaster crossflow muffler,MSD 6A, accell coil, bosch platnum plugs, this car is currently under rebuild and restoration.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The passenger side runner has the EGR tube. The driver's side runner is for the cold-start injector, which your 89 GTA doesnt have. Leave it plugged. You'll have a huge vacuum leak if you dont.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
thanks man, when I put the plenum togeaher to see it all polished and everything I noticed that there was no were to hook it up at there is no holes in the plenum.
thanks for the repily.
[This message has been edited by poncho9789 (edited May 27, 2001).]
no green
Jan 9, 2016 09:22 PM
