need speedo sensor hookup?
Car: 1990 GTA
Transmission: manual/t56
I'm swapping a 350 into my 89 RS and using a tpi system off a 86 firebird. The wiring harness has the connections for an electric speedometer but my car uses a regular cable drive. Will it hurt if I don't hookup this wire? I have a 145 speedo already swapped in and I don't want to go with an electric one if I don't have to.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You should be able to leave that one blank, just make sure you connect your speedo to the ECM the same way as stock (repinning it as necessary) The 86 computer will use either a speedo VSS or a speedo cable.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.23 @ 107.62 MPH
Southern California
Car: 1990 GTA
I'm not really sure what you mean by the computer hookup. I hooked up the original cable from the trans to the cluster. but my camaro doesn't have any wiring from the trans to the computer except the lockup torque convertor and this plug for the vss.
Car: 1990 GTA
Car: 1990 GTA
I'm not sure what you mean by connecting the computer. does it read speed though the dash or something? I have the speedo cable hooked up.
Elephantismo
Feb 13, 2019 12:51 AM
