Help my car idles at 1500rpm!!!!!!!!!!!!!!!!!!!!!!!
Old May 24, 2001 | 11:34 PM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
How do I turn it down to like 500 or so????It won't come out of overdrive,it idles at 1500 in 4th gear and when I take my foot of the gas it won't downshift on its own,please someone help me I am afraid to drive my car!!!!!!!!!!!!!!!!!!!!!!!
Drive it like you stole it
Old May 24, 2001 | 11:51 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
check for a vacume leak or you ACK is stuck
or maby your torque converter is not locking up
cousing a higer stall in 4 gear
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old May 25, 2001 | 12:05 AM
IROCME's Avatar
Car: 1986 IROCZ
It will downshift but it idles at 1500 most of the time like when in park,nuetral,reverse,is there something on the throttle linkage I could adjust??I jst got a new fuel pump if that helps any???!!!
Old May 25, 2001 | 12:19 AM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
most liky it a vacume leak from some were
that is if it just started doing this
also did you get the same fuel pump that was stock
for your car or did you upgrade to an after market
one if you did and its smaller and does not produce
enuff pressure it might run a little lean and couse it to idel higer also but
you would notice a differance in power it would also drop
Old May 25, 2001 | 01:00 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Sounds like what my car did when the TPS went. It wouldn't idle below 1,500 rpm and it would accelerate to 50 mph if I let go of the brake.
Old May 25, 2001 | 07:41 AM
purpleworm's Avatar
I am the champion of this prob I just fixed it!! It ha happened twice to me and nobody knew each time. I need some info about your car and I can prob help you out!!!! A couple of weeks ago it cost me $300 to fix it. I have a really simple test for you. If it is a TPI then pull the linkage where all the cable connect. Pull it toward you and jiggle it around. Mine was idling about 1550RPM's and sometimes 2000RPM's and some times fine. If the car idles down it is the TPS. I have a bunch of other things to try for ya too. E-mail me if you want and I will try to help you.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
Old May 28, 2001 | 03:46 AM
jeff-78's Avatar
My car jsut started doing the same thing recently, and overheated while i was trying to get weezer tickets... i was pretty pissed... it seems like it idles too smooth and consistent to be a vacuum leak, but i could be wrong... I'm gonna check the tps... i disconnected the intake tube in front of the throttle body (which disabled the maf) and it wouldn't run worth ****, so the tps is a definite suspect.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
