52mm throttle blades
Old Dec 11, 2007 | 07:22 AM
Olav's Avatar
Who sells 52mm throttle blades? We have a good machine shop at work so machining is no problem!
Olav
Old Dec 12, 2007 | 02:51 PM
Olav's Avatar
Re: 52mm throttle blades
ttt
Olav
Old Dec 12, 2007 | 03:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You could go to junk yard and ****** the blades off 2 v6 TB's. IIRC they are 52.
Old Dec 13, 2007 | 01:30 PM
Olav's Avatar
Not so many junkyards with US cars here over......I'm in Norway.
Olav
Old Dec 13, 2007 | 03:59 PM
Dale's Avatar
Engine: 350 S-TPI
Sorry, didnt know that.
Old Dec 13, 2007 | 04:48 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
If you have access to a machine shop why not make your own. All you need is a lathe and a parting tool along with some round stock the correct diameter. Heres a picture of my custom throttlebody with a set of 62mm blades. Thats a stock 48mm blade sticking inside the throttlebody.
[IMG][/IMG]
Old Dec 13, 2007 | 06:38 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
haha thats nice good work, what are u running with that? better be a 572 big block or a twin turbo 572ci BB. lol thats wayyyyyy to be a TB for anything under 800 hp. looks good tho. thumbs up! u musta lost a bunch of flow down thow, and throttle response.
they are just 2 round sheets of aluminum. just have them cut out 2 52mm circles form aluminum flat stock and then port the TB to 52mm. i would use 1/16" thick stock, 1/8" max
Old Dec 13, 2007 | 07:08 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Yea they are overkill but throttle response is very good after a lot of tweeking with my chip program. Also,running a six speed and 4:11 gears really helps. Its currently a 402 big block but i have a built 454 in the works.
Old Dec 13, 2007 | 08:21 PM
Dale's Avatar
Engine: 350 S-TPI
884, is that still the stock TB Body, or is that an aftermarket you modified more?
Old Dec 13, 2007 | 08:44 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Dale, that TB started out as a chunk of billet aluminum. The only parts i didnt make are the throtle linkage and the IAC mount. Also the air cleaner adapter started life as a chunk of billet.
Old Dec 14, 2007 | 05:39 AM
Dale's Avatar
Engine: 350 S-TPI
Very nice work then!!!
Old Dec 14, 2007 | 03:22 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Thanks for the props guys.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
Z28/ZR1
Oct 23, 2015 01:04 PM
dusterbd
Sep 29, 2015 08:40 AM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
