Braided hose
Old May 30, 2001 | 07:21 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Braided hose
What is a good way to cut braided hose?
The company I can get it from will not cut it and only sells it in pre-cut lengths....
Old May 30, 2001 | 08:29 AM
irocbsa's Avatar
Wrap electrical tape around where you want to cut and go at it with hack saw with a fine toothed blade.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, Mallory Ignition, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old May 30, 2001 | 12:01 PM
MikeS's Avatar
i'd replace the hacksaw with a bandsaw if you can. cuts back on the back and forth that might rag it out. Not sure how to make the end look finished though. I guess a crimp on thing
Old May 30, 2001 | 12:23 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
After taping the area to be cut I use an air powered cutoff tool (the kind with a little 3 inch fiber metal cutting wheel). It leaves the cleanest cut and is fast
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
Pac J
May 17, 2020 10:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
sheachopper
Jul 31, 2019 11:27 AM
2012sergen11
Oct 13, 2015 07:38 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
