Knock sensor question
Old May 30, 2001 | 03:23 PM
IROCwrangler's Avatar
In investigating my Code 43, I think I have narrowed it down to the knock sensor, so I just ordered one today. I don't have my service manual with me (left it back in Michigan when I moved), so what I'm wondering is:
Is there any special magic to installing one? Is it like a temperature sensor where all the coolant will drain out if I pull it out?
I'm guessing that because I have a bad knock sensor, it is causing the ECM to alter the timing in such a way that it is causing my hesitation, heat problem, sluggishness and occasional backfire. I'm hoping that it at LEAST shuts the damn check engine light off.
Matt
90 Wrangler with 305 TPI motor out of 92 Firebird Formula/ SM465 tranny/ Scout Dana44's on 35" BFG's
Old May 30, 2001 | 03:29 PM
Steve91Z28 L98's Avatar
Car: 1991 Camaro Z28
I just replaced my knock sensor on Sunday. It definitely fixed my hesitation problem and brought back a lot of lost power. Yes, the installation is straightforward, just like a temp sensor. It does thread into the water jacket in the block so coolant will drain out.
1991 Z28 - 350 TPI, T56, McLeod street clutch, LT4 pressure plate, Pro 5.0 shifter, ported plenum & runners, AFPR, Holley Annihilator ignition box and wires, Hooker shorty headers w/o AIR, Flowmaster muffler, homeade ram-air, SSM subframe connectors, Kenny Brown STB, Global West steering box brace, Steve Spohn adjustable torque arm and T56 crossmember
bamaboy0323
Sep 3, 2015 06:07 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
gwade12
Aug 8, 2015 08:17 AM
