How big is your cam??? I have some questions about the idle
Old May 31, 2001 | 04:55 PM
leirch's Avatar
Ok,
My idle on my 219 cam works fairly well now that the prom has some good fuel tables. Now, i was wondering if the thing was sposed to be lopey at idle? Fluctuates from 775-850rpms. Just want to know if that is expected or should it be smooth?
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old May 31, 2001 | 06:35 PM
GTABANDIT's Avatar
My cam is a 248/254 dur @.050 .600intw/1.6 rocker .580exhw/1.5rocker in 383 idle is bumpy but streetable in every day driver has very nice low and mid range power.
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
