How to check EGR componets
I searched and found different answers here. So just to be certain: How do I check all the components on the EGR system for a 1987 Camaro 5.7 TPI engine. I have the components off the car.
EGR- Should it hold a vac off the car or bleed down?
Solenoid- Is this NO or NC and how to test?
EGR temp switch- How to test off the car?
Also how do purchase these parts?
Thanks so much!
Thanks so much!
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: How to check EGR componets
EGR should hold the vacuum when you push in the diaphragm and put your finger over the hole. If the diaphragm releases, its bad.
I dont know the other two answers.
