HELP! My first probs with TPI!
Old Jun 4, 2001 | 09:16 PM
cobrakiller1989's Avatar
I instaled TPI in my 89 RS about 2 months ago and everything was going very well. Just recently the idle got very rich and i was getting a SES light. I pulled the codes and i got a 33 and 36. I bought a new MAF sensor and i already had a new MAF relay so i thought this would solve my problem. when i installed the new MAF i am still getting a SES light. Any ideas? thanks
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLp siamesed runners, Edelbrock high flow intake
*Edelbrock TES Headers (getting SLP 1 3/4 this summer)
*Richmond 3.73
Modded 700-R4, 2800 stall converter
NO recent time slips.
Old Jun 4, 2001 | 09:25 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Switch the other MAF sensor and check the plug. Also check the bellows for leaks.
"Question with boldness even the existence of a God; because, if there be one, he must more approve of the homage of reason, than that of blind-folded fear."
-Thomas Jefferson
Old Jun 4, 2001 | 09:37 PM
Vader's Avatar
CK,
Check the MAF power and burnoff relays. You may have an intermittent connection and/or marginal contacts in the burnoff relay. Make sure the connector at the MAF is intact, and that all engine grounds are solid. The ECM must also be solidly grounded.
You should also set the TPS to design voltage and make sure the distributor connections are good. The ECM relies on the TPS sensor and engine RPM indication to determine what an acceptable range of intake air flow should be. The MAF measurement is compared to this range, and the DTC is set if the MAF is reporting out of range. Your error means the MAF is reporting more flow than should be normal, so the TPS voltage may be a bit low, making the ECM think the throttle is not open as far as it might really be.
Another problem is that your PROM might not be correct for your engine. If the PROM was burned for a smaller displacement engine, the MAF would show more flow than would be the expected "normal" for the smaller displacement. Make sure you have a PROM for a 350.
(Too bad I didn't spell-check...)
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
[This message has been edited by Vader (edited June 04, 2001).]
Old Jun 4, 2001 | 09:43 PM
TPS voltage is at .6 volts and i am sure that i have a 350 PROM. im pretty sure the old MAF is dead because we followed the instructions on how to check it from my uncle's snap on scanner and it didnt show any volts from the "B" pin on the connector. I am going to check the relays and grounds tomorrow. til then, keep the suggestions coming. thanks
Old Jun 4, 2001 | 09:47 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
See, I just go for the easy stuff, Vader hits the hard stuff (and takes the time to explain, unlike some of us!). Teamwork baby!
Old Jun 5, 2001 | 06:03 PM
WOO HOO!!! i found it. a wire came uncrimped from the MAF relay. I soldered it back together and now the car is running perfect(knock on wood) again. thanks for the help guys
84z96L31vortec
Aug 20, 2017 12:16 AM
billybob6110
Sep 24, 2016 09:50 AM
z28addict8490
Sep 5, 2015 03:56 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
