Intake Gaskets???
Old Jun 5, 2001 | 03:51 PM
SillyWabbit's Avatar
Car: '91 Formula
Intake Gaskets???
I just went down to Kragen to pick up an intake gasket set, and I've been looking at it and one thing doesn't really look right. Here's what the instruction booklet says:
<font face="Verdana, Arial" size="2">This set contains 2 manifold gaskets with the center port open, and 1 stainless steel restrictor assembly attached to one of these gaskets.
Use manifold gasket(s) with open center port(s) as supplied in this set or with restrictor assemblies in place as noted.</font>
The instructions then list engine types and whether or not they have open or restricted center ports. The problem is that the only 350 engines they list are for '78-'86, '77, '76, '75, '74 2BBL, '73, and '69-'72. So, I have a '91 L98 350. Do I have open or restricted center port(s)?
My next issue is the end seal(s). I'm assuming the end seal(s) is /are the flexible plastic black thing that came with the set. The only problem I see is that there's only one in the set I got, and it sounds like I need two, one for each side. What's up with this?? Should there be only one end seal, or two? The instructions don't include a parts list, so there's no way for me to tell from that.
Old Jun 5, 2001 | 07:41 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
about that rubber end gasket?don't use it!!!
run a good 1/4 bead of RTV on the front and rear of the block.those rubber gaskets are i big pain in the *** !!!!!
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://discussion-board.com/GreaterC...dyAssociation/
http://www.cincyspeed.com/
Old Jun 5, 2001 | 08:06 PM
Guest
Guest
Posts: n/a
There should be 2 end seals, and dont worry about the restrictor.
I agree with the above tho, ditch the end seals and use silicone.
Old Jun 5, 2001 | 08:19 PM
Car: '91 Formula
Well after going back down to Kragen, and having them get 4 end seals out of another intake manifold gasket set, I've found, like you two have told me, that I shouldn't use the rubber end seals. In fact when I came home with the new seals, I looked at the parts list for the intake gasket set, and rubber end seals aren't even listed! Only the tube of black RTV is. So because it was already opened, the rubber seal was an extra thing that wasn't supposed to be there. Aye Caramba! Oh well, thanks for your help.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
