Does this sound right??
Old Jun 7, 2001 | 10:30 AM
Kyle F's Avatar
There is a guy on the turbo buick board that said he had an older Monte carlo with a 350 TPI in it with Twisted wedge heads, ported intake and a LT4 Cam, stock everything else. Said he was pulling times of 13.45 in the 1/4mile. And when I was like that sounds a little fast for just a head/cam swap alone and asked him about his computer this is what he said
"Everyone is under the misconception that MAF cars can't run the numbers with stock programming. Not true. Back then, I used to manipulate the fuel pump voltage going back to the ecm to increase the base pulse width. Also, it is amazing what you can accoplish with just a scan tool. The Monte ran consistant 13.5's all day long and just happened to launch real well that one time. Needless to say, I didn't have a lot of money, but I did have lots of time to make things work"
I would figure with the heads/cam that the system would barely run on the stock chip.
So is he telling the truth?
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Jun 7, 2001 | 12:42 PM
Synergy's Avatar
He can very well be. I have a friend with a 350 TPI Monte with stock heads but a bigger cam and it runs awesome. I'd say it's a high 13s car right now and with a head swap mid to low 13 is not out of the question even with the stock ECM. People are always under the impression that their cars wont run anymore after you swap a cam, a head, or put exhaust on. ESPECIALLY with SD system. ALL THAT IS BULL****. The car will run and drive well, just NOT up to what it COULD if the EPROM was edited to reflect the mods.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
Old Jun 7, 2001 | 01:49 PM
Guest
Guest
Posts: n/a
I think where a custom chip comes more into play is with part throttle and driveability. 13.5 doesnt sound unreasonable either, I could have run a smaller cam than I have in a G-body and run that time... probably would be less headaches than I am having but I am looking for 12's not 13's.
Old Jun 7, 2001 | 04:43 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
ok with that statement looking at my sig below what else could it be keeping me out of the 13's the car runs awesome doesnt miss pulls hard to 6000 but cant seem to run the numbers i think it should?any ideas?i know it's not a traction problem cause it hooks great,lost in the sauce!!!!!!!!!!1
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
Old Jun 7, 2001 | 09:51 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Pete there is something wrong with your car man. I hat a smaller cam higher gear and 305 heads and turned a 13.9
My 60' time would have been in the 1.9 range though.
You should get a scanning software for you car and see if the computer is throwing the Timing out of wack, or if you chip is not getting enough fuel to your engine. It could be a combinatiuon of things, but something is wrong!!
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
