Where can i get the maf connection extension,,catchy isn't it
Old Jun 7, 2001 | 09:36 PM
Stormshadow GTA's Avatar
somebody mentioned about a company that makes a connection to connect to the maf so you can move the maf further.Anybody have any info on it,hope you know what im talking about.
1987 Trans AM GTA
305 5SPD
Hypertech airfoil
gutted maf
kn filter
High Flow Cat,
3"Walker pipe
Dynomax Super turbo Muffler
TB Coolant bypass
"Three of the scariest letters you will ever see GTA"
Take a good look you won't see em for long
Old Jun 7, 2001 | 11:47 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
find an acdelco supplier and look through their pigtails & harnesses book. You should be able to find something that will work.
Old Jun 8, 2001 | 01:32 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
If you can't find it locally, try SLP...they supply them in their cold air kits.
Old Jun 8, 2001 | 09:38 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
If you get it through the dealer, be prepared to PAY. That connector is around $56!! I bought one last year and paid $36 because I knew the guy in parts and he gave it to me wholesale. There was another guy on here a while back who got that same connector from some fleet supply place for free though, so good luck.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, Rapidfire #2 @ .055", MSD 6AL, 1.6:1 Roller tipped rockers, Homemade AFPR, K&N cone, no airbox, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Descreened MAF, Syclone Fuel Pump, JET Airfoil, Mobil 1 synth in all but transmission.
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Jun 8, 2001 | 12:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you are REALLY interested in saving money, cut the wires, and splice in. (I personallly wouldn't do it but it would work. As long as you use good connections and don't just twist & tape the connections, I wouldn't expect any problems.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
Hotchiss strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
87 Formula TPI (5 Speed) Yellow/Gray STOCK
83 Camaro (Parts)
83 T/A (parts)
]http://www.3rdgenformula.com
BumpaD82
Feb 26, 2016 02:57 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Ranbo108
Sep 9, 2015 12:20 PM
