Heated O2 sensor, which one?
Old Jun 8, 2001 | 04:14 AM
ZaphodB's Avatar
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Which type of heated O2 sensor would be compatible with my '89 IROC? I think I need one, since it takes a while before it works on cold starts (I've got headers, think thats why...).
Would the one for the 93-94 Camaros work okay or what do you others use?
ZaphodB a.k.a Carl Andersson - zaphodb@faxancruisers.org
'89 Camaro IROC-Z 5.7L TPI - Mods under construction :-)
Ed Wright Fastchip Stage II/160 stat, Edelbrock TES Headers,
SLP Airfoil, K&N Filters, Accel 8mm wires, Relocated MAT, AFPR @ 47 PSI
Old Jun 8, 2001 | 12:19 PM
Synergy's Avatar
Go to the parts store and ask for a sensor for a 92 Corvette ZR1.
Old Jun 8, 2001 | 12:22 PM
Guido's Avatar
Car: 2000 Trans Am
I used a ZR1 vette one. I dont remember which wires each hooks to but I can check at home. Someone else will probably chime in here sooner or later though.
I bought mine at AutoZone
-86 IROC
S-Trim, Speed Pro, AFR
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old Jun 8, 2001 | 01:06 PM
mirage2991's Avatar
go to the part store and get a Bosch, 3 wire one, it was teh cheapest i found, works great on my car....paid 56$ I think....
Old Jun 8, 2001 | 01:43 PM
Synergy's Avatar
Doh!.. that's the one from the ZR1 vette!
It's the black wire that's the signal wire. The other two are for the heating element.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
86IROC112
Nov 27, 2015 09:54 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
fonzie85
Aug 13, 2015 11:50 AM
