For my folks that got scammed
Old Dec 28, 2007 | 01:57 PM
BadAz_Iroc's Avatar
For all the guys that got scammed, that **** was wrong and you are doing the right thing by going after him. Anyway, there is a speed shop in Baton Rouge La. call Thunder racing i am pretty sure you heard of it, but they have the HSR for $359.99 go check out there web site.
Old Dec 28, 2007 | 03:12 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: For my folks that got scammed
Not a bad deal, have to get new rails though.
Old Dec 29, 2007 | 12:49 AM
czbigboy's Avatar
Car: 85 IROC Z
Is that speed shop pretty big? I live about 1hr away from there.
Old Dec 29, 2007 | 10:48 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
if you look to the right of your screen, you will see that Thunder Racing is a sight sponsor.
Old Dec 29, 2007 | 11:06 PM
czbigboy's Avatar
Car: 85 IROC Z
As soon as I get home from Iraq I am going to go check them out.
Old Jan 2, 2008 | 10:42 AM
BadAz_Iroc's Avatar
I use to live in baton rouge, and it was small, but since they move, it ia pretty big now, there are some other nice speed shop there also, oh yeah, some nice street racing on the weekend also.
Old Jan 2, 2008 | 11:37 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I bought my HSR manifold for $300, then spent $180 on the non-adjustable kit from summit racing.
Summit has the manifold/base for $309, and the non-adj rail kit for $180, adjustable rail kit for $230.
I'm sure that Thunderracing will price match it.
Manifold + base - WND-7540
http://store.summitracing.com/partde...5&autoview=sku
Adjustable Fuel rails - HLY-534-186
Non-Adjustable Fuel Rails - HLY-534-185
Old Jan 2, 2008 | 08:22 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
It says on Summit that manifold does NOT work for our cars, well past 86 anyways, and they also say for the vortec heads. Correct me if I'm wrong.
Old Jan 2, 2008 | 08:34 PM
Works just fine. You'll need beveled square spacers for the 4 center intake bolts to adapt the intake for a later 87+ heads. The 4 center holes were drilled at 90* versus the older heads which it had them at 72* like earlier heads. The spacers are available from McMasterCarr's website for about $6 + shipping for 8, you'll only need 4.
I had it on my 89 GTA with latermodel heads.
You'll also need a small cap distributor with remote coil if you don't have one. You can snag one from any 87+ 305/350 tbi/tpi engine. There are already articles on the net.
If you want more specific information go to www.stealthram.com for more info.
Beveled spacers - Part# 92810A130 on www.mcmastercarr.com You might need slightly longer bolts to adjust for the difference. However I reused the stock ones without any leaks. You can see how the spacers are used in the attached pic. Sorry for the dirty engine bay, I spilled a little oil and didn't clean it up.
Old Jan 2, 2008 | 08:54 PM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Hm, looks cool, can you use the TPI Throttle body, 'cause I would hate to get rid of my BBK TB.
Old Jan 2, 2008 | 09:00 PM
cwyates4's Avatar
Car: 85 vette/87 TA
Engine: built 383/350 tpi
Transmission: built 700r4s
Axle/Gears: 3.45 dana 44/ 3.27 9 bolt
tpi throttle bodies work just fine.
one question, will these spacers work to adapt 87+ heads to any pre 87 intake?
Old Jan 2, 2008 | 09:31 PM
Yep. I looked up the price too. $5.67 for 5 spacers. Add shipping to that though. Still shouldn't be anywhere near the $60 or so they want for the adapter kits. The Aluminum is VERY soft on the spacers, so put a steel washer on there to spread the load and not take any chunks out of it.
For the throttle body you will probably need to slightly bend the nautilus style throttle cable bracket to clear the fuel rail. Or you can clearance it with a dremel to make it fit.
The HSR is a very cost effective upgrade. Minor loss below 4000rpm, but after that you'll gain nearly 1,000rpm of extra power to play with. The other intake that looks promising is the BBK Turtle Ram which will be emissions legal, but hasn't been released yet, and no firm date either. A real tune is a must though.
If I were to build another TPI car I'd go HSR or converted LT1 intake no questions asked.
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
3.8TransAM
Oct 1, 2015 07:47 PM
3.8TransAM
Sep 27, 2015 08:37 PM
327IROC85
Sep 23, 2015 12:11 AM
TrevinE
Sep 14, 2015 03:20 PM
