HELP!!!!!!!!!PLEASE!!!!!!!!!!!
Old Jun 8, 2001 | 10:01 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Anybody know if the engine wiring harness for a 87 GTA tpi would be the same for digital dash vs analog dash. And if it would be the same from a 86 IROC. I have purchased a 87 gta with digital dash that had a engine fire and need to know if the iroc computer harness will work.
89 Iroc 350 TPI,
Forged pistions
Comp roller Cam .510 lift 230dur
Flowmaster exhaust
Dart Iron Eagle heads 200cc runners 64cc chambers
MINI RAM SOON!!!!!
stock TPI for now 24# inj
Old Jun 8, 2001 | 12:28 PM
MAXGTA2002's Avatar
it will work, just keep in mind, Is it maf or
map harness, Do you have mass air or speed density, thats the question and is it TBI or TPI.
Old Jun 10, 2001 | 04:18 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
there are a few differences but should work the harness has nothing to do with the dash the dash is a way of reading your engine which uses sending units to bring them together
87 trans am 350 L98 aluminum heads,LT4 hot cam,slp runners,headers,y-pipe,edelbrock base,hi flo cat,air foil,ported plenum,t-5 tranny w/centerforce clutch and a 3.27 9bolt,ads strip chip,relocated iat sensor,hollowed maf
14.10@97mph w/2.01 60' 4SALE anyone want her?
