Went to track for first time,, results within
R/T 1.204
60' 2.09
330 6.054
1/8 9.332
MPH 73.05
1000 12.169
1/4 14.583
MPH 92.29
@ Englishtown Raceway Park
I'm kind of dissapointed, figured with all the mods i'd do better, but this was the first time ever racing and it was hot out. i had 2 runs before this with 14.7X times,, the first run i went 94mph, second i went 91mph, with the same 1/4 mile time.?? whats that mean? I also had on drag radials.. on my last run i got the rpms up to 1000 then launched, i guess it helped,, shaved off .2
let me know what you guys think about the times and what they mean...
i need to advance my timing, hopefully thatll give me more power..
Ron
1988 GTA Trans Am 350tpi: 48k miles,3:27 BW rear, aftermarket t-tops
Hotchkis: subframe connectors & strut tower brace
Flowmaster: 3inch exhaust& dual chamber muffler
Accel: 8.8mm wires, cap&rotor, u-groove spark plugs
Edelbrock: 52mmTB, intake & runners
K&N: filtercharger
TPIS: 170* stat, afpr, mat relocation kit
March: performance crank and alternator pulleys
Hypertech: 176* fan switch
Other mods: ported plenum, gutted cat, tb coolant bypass, homemade cold air induction, flux capacitor, driver side floor mat removed
60' 2.09
330 6.054
1/8 9.332
MPH 73.05
1000 12.169
1/4 14.583
MPH 92.29
Ron
K&N: filtercharger
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
What elevation is the track at, and how hot was it? Both of those things could make your ET seem slower than it is. My only reccomendation would be to launch at a much higher RPM. When you're sitting at the lights you should have your engine at the highest RPM you can before the back tires break loose, which with a stock converter would probably be in the 1200 - 1500 RPM range. That way when the green hits, you lift your left foot off the brake and nail the gas with your right. You should see the difference in your 60' times. Look at your slips from the off idle, and 1k RPM launches you made. I guarantee you most of the .2 difference you saw is right there.
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Stock PROM
E.T.F.A Member #11
Black 88 GTA L98
261 RWHP, 345 RWTQ
13.406 @ 103.72 MPH
E.T.F.A Member #11
Dont wait for the green like the above post says....you are sleeping at the line. Leave on the third yellow. 60ft should be much better with drag radials...I get that 60ft on my street tires. Make sure you are doing a full burn out, and launch at the highest rpm possible.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] My 86 IROC 305 TPI Page (406 build in progress)
ET's @ 1250 ft[*] 14.28 @ 95.461 mph (uncorrected, NOS, no headers)[*] 15.362 @ 88.238 mph (uncorrected, headers, no NOS)
<font face="Verdana, Arial" size="2">Originally posted by Scott 88 GTA:
</font>
</font>
yes i realize the reaction times suck, but this was the first time ever at the track,, i had no idea what was going on.
thanks for the info guys
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
you should be running WAY better times with those mods....check out my response on the "13's????" thread...
Originating member of the SJNEP Crew
Member of the Jersey Fbody Crew(JFA)
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM RiceEatinGTA***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Tony
Hmmm, seems ok, but you should be a little better. Add some fuel. Don't worry about reaction time, ( I have no idea what these guys are talking about) that doesn't matter. Clock doesn't start until you trip the beam. You go when you want to. Get some diagnostic software and see what is happening. I think you should be having a higher trap speed than that. What is your timning set at? A 2.0 60 isn't that great either, but what can ya do on radials? Get some software, run it, and give us the info on what is going on and we can better help you.
-Bill
-=1987 Buick Grand National=-
Almost Jacked Up Like a Mother
*CC 218/218, ported and polished heads (1.77, 1.50), Accufab AFPR, custom DP by Custom Tubes,
Walbro 307 hotwired, Big Mouth cold air intake, 009s, custom PROM and 20psi of fury*
Wanna try me?
-=ICON Motorsports=-
Modertor TPI board
-Bill
Wanna try me?
Modertor TPI board
Car: 98 Chevy Z-28
Engine: 346ci LS1
the conditions were fine...I ended up running a best of 14.59@93.xxmph that night...I actually talked to Ron for a few mins about his car...his car is probably a bit heavier than mine but other than that I dunno what was up with his ride. His 60's were much better than mine by about a whole tenth so really he probably shouldve been running 14.4's or better but as u could see his mph wasnt quite there to get the job done. Anywayz...
lata
Bill
Check out other members of DSI Racing at:
www.geocities.com/foff667
www.geocities.com/njspeeder
www.geocities.com/mgd78
http://members.fbody.com/96SilverStreak/home.html
lata
Bill
Car: 89 IrocZ
Engine: L98-ish
<font face="Verdana, Arial" size="2">Originally posted by Bill87GN:
</font>
</font>
Who wins the race?
That was my point, albeit with just some good natured ribbing.
<font face="Verdana, Arial" size="2">Originally posted by Raymond 5.7 89 Formula:
Ron was looking at your mods and was wondering do you have headers on there?</font>
nope, no headers
What happens when you hit 88 with that setup? With that flux capacitor the time travel might be slowing you down </font>
I think you should be having a higher trap speed than that. What is your timning set at? A 2.0 60 isn't that great either, but what can ya do on radials? </font>
timing is 6*- stock
i had on drag radials, not regualar radials
[This message has been edited by ron rizzotti (edited June 10, 2001).]
Car: 87Z
Engine: ?
Transmission: A4
Here is a heart braker time slip for you.
R/T .664
60' 2.098
1/8 9.355
MPH 74.60
1000'12.221
1/4 14.612
MPH 93.39
By the way thats a 305 with 126,000 miles on it.
87 Z28 305 TPI, Auto, LT-1 cam (@.50 418/430, 194/199, LSA 111), roller timing set, 2.73, Gutted air boxes, K & N fillters, Dyno Max 3" cat back, 8.8 mm spirals, air foil, BFG Drag radials,170* Stat and TB bypass.
Old Best 15.414 @ 87.47.
new best 15.006 @ 89.55.
w/ drag radails 14.6 @ 93
“Fallen But Not Forgotten”
R/T .664
60' 2.098
1/8 9.355
MPH 74.60
1000'12.221
1/4 14.612
MPH 93.39
<font face="Verdana, Arial" size="2">Originally posted by new87:
R/T .664
60' 2.098
1/8 9.355
MPH 74.60
1000'12.221
1/4 14.612
MPH 93.39
</font>
R/T .664
60' 2.098
1/8 9.355
MPH 74.60
1000'12.221
1/4 14.612
MPH 93.39
</font>
If that was recent, you should be even better when the humidity improves. O.K. What's the latest mod? That's quite an improvement, and very nice for stock exhaust manifolds! Get the 1.6:s installed? Just curious what it takes to get the 305 tweaked...
Ron,
Don't sweat the reaction time. You are racing the clock/traps at this point, not the guy or girl in the next lane.
Your time SHOULD be a bit better. Have you played with the TV cable setting to max the shift points? If you're over-revving and gasping for air at 5,000 RPM shifts, you could really be hurting the times.
Also, don't be afraid to bring up the RPMs at the tree a bit more - it can help get the power to the wheels a lot faster.
On the bright side, you're already beating most of the Mousetanks you'll encounter on the streets, so it only gets more embarrasing for them as you improve the launches.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Car: 87Z
Engine: ?
Transmission: A4
<font face="Verdana, Arial" size="2">Originally posted by Vader:
Nice shootin' New!
</font>
Nice shootin' New!
</font>
[This message has been edited by new87 (edited June 10, 2001).]
<font face="Verdana, Arial" size="2">Your time SHOULD be a bit better. Have you played with the TV cable setting to max the shift points? If you're over-revving and gasping for air at 5,000 RPM shifts, you could really be hurting the times.</font>
i adjusted my tv cable that morning, but i noticed when i was racing the rpms went up to like 6000 before shifting.. why is that?
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
hey new87 you should be running better than that. my 305 5 spd with the stock cam and heads, and only headers and gutted airbox, screens off the mafs, and no cat runs 14.48 @ 95 on street tires with 2.2 60ft times.
do i just have a freak or something?
i do have 3.08 gears but not much of a difference between that and your 2.73
Andrew
Andrew
<font face="Verdana, Arial" size="2">Originally posted by smokin87iroc:
I do have 3.08 gears but not much of a difference between that and your 2.73
Andrew</font>
Andrew</font>
Later,
Vader
