new TPS bad?
Old Dec 30, 2007 | 10:42 AM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
new TPS bad?
first my car has 40k miles with full exhaust with headers ported intake and some bolt-ons.
ive been having cold start problems. so i did a tune, cap, rotor, NGK plugs, MSD wires, new IAC, FMU, tested the fuel pump and was fine.
so the last thing i tried was a new TPS. when i put the new one in it started right up but idles about 2000rpms and now i have a check engine light. threw the old one back in and no check engine and idles about 800.
im lost on this one any help?
Old Dec 30, 2007 | 10:47 AM
SDTransAM's Avatar
Car: '83 z/28
Axle/Gears: Stock?
Re: new TPS bad?
Did you set the TPS voltage?
Old Dec 30, 2007 | 11:26 AM
BulliTooth's Avatar
Car: 1989 Formula
Re: new TPS bad?
no i did not. now let me get this right, TPS voltage at idle should be .54 volts. TPS voltage at WOT should be 4.49 volts right? what should i use to check voltage? thanks
Old Dec 30, 2007 | 12:44 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: new TPS bad?
Correct, around 0.5V with closed throttle, close to 5V at WOT. You can test it with a voltmeter and the key on. Test the blue wire on the TPS.
If you replaced the new TPS with the old one and that corrected the problem, I'd suspect the new TPS.
Lou
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
earlpote
Sep 12, 2015 11:55 AM
