Any Other Free Mods??
Old Jun 12, 2001 | 09:51 PM
SillyWabbit's Avatar
Car: '91 Formula
Well, Monday, I put my car back together after I replaced the valve cover gaskets, ported the upper plenum, and did the throttle body coolant bypass. Other than these, what other "free" mods can I do??
Old Jun 12, 2001 | 10:51 PM
Vader's Avatar
SW,
Maybe not completely "free", but inexpensive, at least:
Change to 180°F thermostat. You might as well flush and refill the cooling system while you're at it, so plan on about $20.00 in parts and antifreeze;
Add an auxilliary fan switch to control the radiator at 200°F - $21.00 for the switch and a few feet of wire;
Convert to an adjustable fuel pressure regulator - $30.00 for gaskets if your new plenum gaskets are already baked in place;
Adjust the TV cable for optimum shift points;
Adjust base timing for optimum performance (may require a scan tool to monitor knock counts);
Bolt a steel stiffener plate behind the steering gear box ($6.00 for a ¼" steel plate);
Gasket match the exhaust manifold to the heads;
Increase the TPS voltage at idle as long as you remain below 0.60VDC;
Read the "Free & Cheap Mods" section in the Tech Articles.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
Hotrodboba400
Dec 10, 2019 07:07 PM
Nervous2
Oct 8, 2015 10:53 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
