Ticking SVO injectors
Old Jun 14, 2001 | 06:50 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Just to let you know, my SVO #24 injectors ticked very loudly after the install. I took some 1/16 rubber washers and installed them between the fuel rail bolts and the intake fuel rail bolt towers. Torqued everything down, probably flattening the washers to 1/32". The ticking is gone, sounds like any other TPI again! My injectors sit pretty far in the holes and my clips worked and I used GM o-rings so I'm not worried about leaks.
later
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jun 14, 2001 | 10:15 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Thanks for the FYI....I have a set of 30s for the 406 IM building. I just might try the rubber washer trick myself. I really dont know what to expect with these injectors. Some are having problems with them.
So you used GM O rings? whats wrong with the ones that come with the injectors? Slightly different size?
Mike
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Jun 15, 2001 | 12:12 AM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by MikeH:
</font>
Maybe, maybe not. I have a set of 30's I just got about a month ago, the o-rings are exactly the same size as the GM ones. You'll have to take a look for sure, I have heard about some being smaller although I dont know for sure.
Old Jun 15, 2001 | 05:24 AM
Rob P's Avatar
Engine: ZZ4TPI
I'm pretty sure I used the o-rings that came with the SVO's and they fit very nicely in my edelbrock intake. I've heard that SVO's sit rather deep in the edelbrock and part of the injector actually touches the intake, causing the loud ticking (sound travels through a solid better...).
I've been monitoring for leaks and everything is great.
Rob P
89RSconvtZZ4TPI
1 5/8" Headers
92Z28convt5spd
Old Jun 15, 2001 | 03:37 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Yep...They fit nice...I Just tried one in my Accel base and no problems. Have to wait and see how they work with the fuel rail installed.
I would have probably tried the Accel ones. If they would have been out at the time I started this project. Even though they look like the same damn injector just a different color.
Old Apr 28, 2004 | 06:41 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Im having a similar problem with a edelbrock baseplate, and SV0 36# injectors. Its soo loud, you can feel it through the rail, the lines,etc.
I'm curious if this could even trigger the knock sensor, which I'm seeing as an issue too.
-- Joe
92-Formula
Dec 12, 2015 10:34 PM
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
