O2 sensor
Old Jun 14, 2001 | 04:00 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
O2 sensor
I just recently converted my car to TPI, and it runs...ok...honestly I was hoping for more of an improvement over my 4bbl.
When I sit at a stop light and it idles about 500RPM warm, my Check Engine light comes on, as soon as I take off, it goes out. i get a code 44 (Lean Exhaust indication). mods listed below: if the idle is around 700RPM it does not come on at all.
87 Formula 5.1 converted to TPI Yellow/Black
SLP cam, headers, cat-back exhaust
Ported & polished TPI intake
Gil Younger (no yo-yo) Shift Kit
Aluminum Driveshaft
3.73 Posi gear
Baer 12" brakes 4 wheels
KYB AGX Adjustable Shocks & struts
Hotchkis strut tower brace
South side machine frame connecters
Custom reinforced control arms and pan hard bar.
Custom Leather interior
CUSTOM Yellow Gauge Faces
87 Formula TPI (5 Speed) Yellow/Gray STOCK
1967 Buick Riviera 430hp Turns high 14's (Not bad for 4300 lbs)
83 Camaro (Parts)
83 T/A (parts)
http://www.3rdgenformula.com
Old Jun 15, 2001 | 11:29 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Are you running a mass air system or map ??
Did you spill any coolant on your TPS? IAC??
Ive troubleshot this problem before, mainly on 2.8s but the electronics are similar..
-- Joe
Old Jun 15, 2001 | 11:31 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Old Jun 16, 2001 | 12:03 AM
Vader's Avatar
OK,
Try resetting the TPS voltage, cleaning the IAC, and setting the minimum throttle position. That should get your idle closer to normal.
The check engine light is probably due to low oil pressure or the TPS setting. You can scan the ECM for error codes to make sure.
Later,
Vader
"Let the bodies hit the floor!"
Adobe Acrobat Reader
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
