How will my car react to bigger injectors????
Old Jun 16, 2001 | 03:20 PM
CamaroX84's Avatar
Well, I have to replace at least two of my fuel injectors. They are both pretty much dead. I figured, since the injectors have 90,000 miles on them, I may as well replace them all. Since I am replacing all of them, and I eventually may need bigger injectors if I ever buy a Super Ram, how will these bigger injectors affect my car's performance? Will it benefit (more power/fuel economy) or will it be hurt by adding these injectors? Also, what brand of injectors do you guys like, and where can I get them for a reasonable price? All of my mods are listed in the sig. Thanks in advance.
[This message has been edited by CamaroX84 (edited June 16, 2001).]
Old Jun 16, 2001 | 04:26 PM
88 IROC BOB's Avatar
I've heard of some people having problems with codes when running 24 lb injectors unless your into burning proms.
I am going to get a set of Accel's. They make 23 lb injectors which supposedly causes no problems.
Talk to Rich @ www.cruzinperformance.com
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Old Jun 16, 2001 | 07:13 PM
whiterocz's Avatar
the computer will just compensate for the bigger injectors by shortening the pulse width to the injectors. of course this is only in closed loop. in open loop, if you havent done quite a bit of breathing mods, you might run a bit rich.
[This message has been edited by whiterocz (edited June 16, 2001).]
Old Jun 16, 2001 | 07:31 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
90,000 miles and they're dead already?? My '86 TA has over 200,000 miles on it and the injectors are the originals from GM! Guess some people are just a little less lucky than others!!
I'm replacing my engine soon with a 350 and I'm putting LT1 24# injectors in mine! I got a steal of a deal on a complete set of LT1 injectors and I just recently sent them off to Rich at Cruzin Performance to have them cleaned an flow matched! Check out his site www.cruzinperformance.com .... for $80 he will clean the injectors and flow match them so that they flow better than they did from the factory... as well as installing new screens and o-rings, it's a good deal!
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.5:1 Compression, Stock TPI ported, 24#/hr LTI injectors, Hedman Shorty Headers, SBC Stock Casting heads pocket ported, Comp Cams XE262-14 TPI Cam, Ed Wright Fast Chip, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Box, Hypertech hot coil!!
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
