How do you adjust the fuel/air mixture? I read the.....
Old Jan 4, 2008 | 09:34 PM
billybengal's Avatar
article that you can do this with you Oxygen sensor. It tells all about pluging the wire, digital volt meter etc but then the question is, how do you adjust it? With an Adjustable Fuel Pressure Regulator? Or what? This may sound dumb, but I'm just not a born mechanic (rather one that learns his stuff day by day).
Also, the article specifies what the voltage should be at wide open throttle. Should I meassure in Park in my driveway or should I measure while driving (sounds like a stupid idea). I need specifics please (like a SQL statement ;-))
Thank for the help guys!
Old Jan 5, 2008 | 02:45 PM
Imthebriman's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
Re: How do you adjust the fuel/air mixture? I read the.....
Dude, Im sorry but I think you are refering to adjusting the TPS (Throttle Position Sensor) You should measure it in park and you don't even have to start the car. Just make sure the key is turned on, or you won't get any voltage.
Old Jan 5, 2008 | 03:08 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
setting the fuel/air mixture by the O2 sensor is for carburated motors. it doesn't apply to GM fuel injected motors.
which one do you have?
Old Jan 5, 2008 | 04:23 PM
Thanks! That solves it. Yep, I got a fuel injected one. Learning one thing a time. Thanks again.
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
deracer
Apr 11, 2016 12:04 AM
BurlyChev
Aug 22, 2015 11:42 AM
86IROC112
Aug 21, 2015 12:39 PM
