LT1 cam in L98?
Old Jun 15, 2001 | 10:57 PM
badZ-28's Avatar
LT1 cam in L98?
I was told that you can use a LT1 cam in a L98. How much can I expect to gain if I do this? Also will a LT4 cam work? If so what will the gain be with this cam? Thanks.
Old Jun 16, 2001 | 07:30 PM
whiterocz's Avatar
yes you can. you need to shorten the dowl pin just a hair on the camshaft but it will work. the stock LT1 cam will perform slightly better than the L98, but the LT4 Hot cam will give you a lope at idle and will rev to 6000rpm+, but your TPI will not pull to 6000rpm. but just by changing to the LT4 hot cam, you will see im guessing ~20-30hp.
Old Jun 17, 2001 | 09:25 PM
badZ-28's Avatar
Whiterocz do you feel it is worth changing to the LT1 cam or would it be a waste of time? Also would the LT4 cam effect my gas mileage by a lot?
Old Jun 18, 2001 | 01:03 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A better cam for a stock L98 is the ZZ4 cam. Check the cam tech article on this site for more details on other good cams for L98 engines.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
lt500r55
Sep 1, 2021 01:30 PM
midge54
Dec 27, 2019 04:14 PM
italiano67
Aug 31, 2015 06:04 PM
midge54
Aug 29, 2015 09:51 PM
TheExaminer
Aug 19, 2015 10:07 PM
