Wont stay on
Old Jan 7, 2008 | 08:47 AM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Wont stay on
Wassup everyone. I having a bit of a problem here. I recently bought a 89 Formula 5.7 TPI Firebird. I was told originally that it needed a fuel pump. Normally I wouldnt buy a car if it wont start but I got it dirt cheap from a reliable person that my dad has done buisness with for some time. Its a donation vehicle place. Usually I do all my own work with my pops, but since this job is a bit more intricate we decided to let a shop handle it. The car was not starting when I got it. It wouldnt "turn over". So I bought the fuel pump and brought it with the car to them. They changed the fuel pump. Later we discovered the car was getting no spark and we found out the ignition module (I believe thats its name) was bad. We had this changed too. Now the car turns on, but it wont stay on. Turns off Immidiately. So the guy (mechanic) told me it might be the fuel injectors, but he isnt sure yet. Its about 10am Monday morning that I am writting this. I told him I'd give him a call around 1ish. Hes gonna check it over to see if he can find what exactly is causing the car to shut off. A fuel injector set is pretty expensive and Im hoping its not the problem. Does anyone have any idea as to what would cause it to turn off after being turned on? Any insight would be helpful. Thanks in advance.
Last edited by Robb Knight; Jan 7, 2008 at 08:48 AM. Reason: spelling error corrected
Old Jan 7, 2008 | 09:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Wont stay on
Disconnect the MAF and see if it starts and stays running.
Old Jan 7, 2008 | 09:10 AM
Engine: 5.7 350 TPI
Re: Wont stay on
Is that the mass air flow sensor you are speaking of? Oh yeah and if thats the case, where is it located in the car?
Old Jan 7, 2008 | 09:18 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Wont stay on
Yes. It's part of the intake tubing about halfway between your throttle body and air filter. Round hard plastic. The 4-wire connector should be underneath of it.
sheachopper
Jul 31, 2019 11:27 AM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
bigjay89gta
Oct 15, 2015 08:04 AM
lewandom
Oct 1, 2015 08:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
