350 efi to tpi help
Old Jan 8, 2008 | 03:50 PM
ckozrun's Avatar
350 efi to tpi help
k guys... my lb9 just recently crapped the bed when the head cracked on me... i did some looking and ended up with a brand new 355 efi engine for free. woohoo. frees good..( thanks girlfriends dad) now i have some questions about changing the fuel system on the 350efi to tpi. would it be possible for me to change heads on the efi to a chevy 350 tpi performance head and from there up put on all the 305 tpi gear. i know ill have to go with 22 lb injectors, change the knock sensor, and get a diff ecm. wat you think
Old Jan 13, 2008 | 12:40 PM
ckozrun's Avatar
Re: 350 efi to tpi help
anyones?
Old Jan 13, 2008 | 01:15 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Just make sure these performance heads that your planning on can be used in conjunction with whatever year your LB9 TPI intake was produced. If your using pre-86 cylinder heads w/an '87-up LB9 intake manifold, you'll need to elongate the four middle bolts on the intake manifold so it will be able to seat properly to the cylinder head. Also, you can keep the original ECM, just change the memcal (chip)....
Old Jan 14, 2008 | 11:50 AM
ckozrun's Avatar
thanks man... now its time to tear her apart.
Old Jan 14, 2008 | 11:56 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
I'm missing something. tpi (tuned port injection) is a form of efi (electronic fuel injection). What injection system does the new motor currently have?
Old Jan 14, 2008 | 12:12 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
could be throttle body....
Make sure you use injectors from a 350 and not the 305.
Old Jan 14, 2008 | 03:13 PM
kanmudhog's Avatar
Car: 89 formula ws6
Engine: yes
Transmission: yes
Axle/Gears: both
Check the knock sensor and make sure its compatable and don't forget about the egr system when looking at new heads .
Old Jan 14, 2008 | 05:21 PM
ckozrun's Avatar
yes its a throttle body... my girlfriends dad was gonna put it in his truck but unfortunatly some lady totalled his truck before he could . its a 355 from jegs. so as long as i got the right heads the tpi system from my 305 will fit right?
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
