Setting Timeing
Old Jun 18, 2001 | 05:10 PM
Urbs87GTA's Avatar
Setting Timeing
Ok I just rebuild the 350 in my gta and i have it all together in the car and it runs but I can't seem to get the timming right. It gets close and sounds good then it gets really rough and sometimes stalls out. I did disconnect the signal wire from the distributor to the computer. Is there anything else that i am missing. Is it just a vacuum leak or are they just hard to set??
Old Jun 18, 2001 | 06:46 PM
rondubbs's Avatar
you disconnected the correct wire, right?
the EST wire thats on the passenger side firewall, tan in color, ??
also did you put it in correctly? it may be 1 tooth off or 180* off.
[This message has been edited by ron rizzotti (edited June 18, 2001).]
Old Jun 21, 2001 | 04:43 PM
Urbs87GTA's Avatar
I got the right wire it is tan and by the heater box. How do you determin if it is off one tooth?
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
