Carb to TPI Swap
Old Jun 21, 2001 | 03:00 PM
Jax86SC's Avatar
Carb to TPI Swap
I'm sure this question has been asked, but the majority of search results are for a TPI to carb swap.
Here's the skinny:
Have a great deal on a complete Edelbrock TPI system (intake, runners, plenum, etc.) and BBK throttle body. Also comes with Mallory ignition system (dist, coil, etc.).
Current car is 86SC with 305, QJCCC, and auto trans.
Question is what else will I need to complete this swap? Which harnesses? Anything for trans? This system is basically everything from the intake up with the exception of the Mallory parts.
Old Jun 21, 2001 | 06:06 PM
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Sounds like a good deal. First and formost, you'll need the fuel system, ie injectors, fuel lines, and fuel pump. Then you'll need an ECM to operate it. You can go stock, but will have to match the ECM to either MAF or MAP systems, or go with an aftermarket MAP system. The harness should be matched to the ECM. You know, it does sound like a good deal, but I can tell you it's a lot of work. I did TBI to TPI, but you will have more to do then I did.
good luck, either way
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Rider's Ride
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
gta90
Sep 15, 2015 04:00 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
