2nd Knock Sensor?
Old Jan 10, 2008 | 06:58 AM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
2nd Knock Sensor?
Hey whats up! The other day I was tightening the passenger's side header on my car due to a leak when I discovered what appears to be a 2nd knock sensor! Its located under the 2nd primary towards the back! or is it a knock sensor? I know that the other sensor is lcated in between the 1st and 2nd primary which is easy to access. Do I happen to have a different type of engine or something??
Thanks,
Ruben
Old Jan 10, 2008 | 11:49 AM
vbMike's Avatar
Car: 1987 Camaro IROC-Z28
Engine: TPI 350ci L98
Transmission: T56 - Hurst Shifter
Axle/Gears: BW - 3.70
Re: 2nd Knock Sensor?
Sounds like the temp switch used to turn the fan on.
Old Jan 10, 2008 | 12:20 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought that was the dash temp sending unit?
Old Jan 10, 2008 | 12:31 PM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The knock sensor is down low next to the oil pan rail and installed in an existing block coolant drain plug hole.
The dash temp gauge sensor is installed in the drivers side head. Electric cooling fan cars will have another temp sensor installed in the passenger side head. The ECM temp sensor is usually installed in the thermostat housing or intake coolant runner.
Old Jan 10, 2008 | 12:44 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The ECM turns one fan on, the switch in the passenger head turns on the other one.
Old Jan 10, 2008 | 07:18 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Oh so thats what that is ! Looked like another knock sensor to me but now I know what they are! Hey I appreciate the info guys!
Thanks!
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
